Configure multicast stream limitation to limit the number of concurrent multicast streams on the interface. By limiting the number of concurrent multicast streams, you can protect the bandwidth on a specific interface and control access to multicast streams.
You can configure the maximum number of streams independently. After the number of streams reaches the limit, the interface drops additional join reports for new streams. You can control the overall bandwidth usage in addition to restricting users from receiving more than a specific limit of multicast streams on an interface.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
- Select IGMP.
- Select the StreamLimit tab.
- To change the status of an interface, double-click StreamLimitEnable for the interface, and then select enable or disable.
- Optional: If the interface is enabled, you can edit Maximum Number of Stream.
- Select Apply.
StreamLimit Field Descriptions
Use the data in the following tab to use the StreamLimit tab.
Name |
Description |
Interface |
Displays the slot and port number or VLAN ID for this interface. |
StreamLimitEnable |
Enables or disables stream limitation on this interface. |
Maximum Number Of Stream |
Configures the maximum number of streams allowed on this interface. The range is from 0–65535, and the default is 4. |
Current Number Of Stream |
Displays the current number of streams received on this interface. This value is a read-only value. |
